For those of electronics noobs like me normal size 5k resistor works just fine no need for smd. My cheap multimeter reads 200mA while charging a random 18650 battery.
It is perfect of neatness!!!
Is there any place other than thingiverse on on tho get the remote parts? I see some with place for the LED’s and other changes that I can’t find in the thingiver list.
Cheers!
You could always drill carefully and make the hole yourself
The LEDs are no longer supported, as everything is displayed on the display
Hi guys is there someone who are willing to Print the parts for me and send them to me , only USA i paid ofc. Thank you
Where exactly do the magnets and the hall sensor go in the housing? Also I don’t understand the wiring for sv on the hall sensor and sv on oled. Where do they go exactly?
Magnets into the holes ind the throttle 3d print and in the buttom deres at slot for the hall sensor
Wow thanks a lot man. Do u know exactly how the wiring goes for the oled sv and the hall sensor sv
Yes do I splice the hall sensor 5v into the oled 5v?
Basically just all 5v needs to be connected from the boost converter output
All the 5v wires go into the 5v pinout?
Got it, one more question, all the grounds I don’t need right? I don’t need to put any of them in the gnd of the arduino right?
You do yea. Otherwise your not finishing the loop. The ground needs to be connected just like 5v but all grounds together.
Meaning all grounds to the same pinout? Also can I connect the switch to a6 instead of d4?
Aslong as the arduino i reciving ground from the boost connector it dosent really matter which of the ground outlets you use on the arduino
What about the grounds from all the other things? They can all go to the same ground on the arduino?
