Last units left for this discount hurry up if interested
Could these be altered to accept a leopard 8072?
There are no space 80mm will not fit next to hanger.
Damn⌠guess Iâm stuck with belts until u or jens make gear drive for non-mtb trucks
Why u need 80mm motor on caliber hanger?
Cal,SRâs doesnât matter really⌠and I wanna finish shadowmere
Sorry but I didnât understood what you mean
Surfrodz, calibers the trucks donât really matter, just rather not have mtb trucks because of the adapter I would need
And shadowmere is the 1st build I started, then got hit with needing a board instead of just wanting one so I went for a commuter build.
That was the build where I wanted to use 2 of the 80cc rotomaxâs and u convinced me to search for other alternatives because of their mounts
Does V2 mini drive train work on FB 240 mm? Same base plate is used.
Yes FB230/240 mimics caliber hanger profile so tb218/caliber style mounts work.
The last unit with 3.75" wheel hubs for (Trampa/MBS tires) is on sale -20% (BF discount doesnât apply) This unit was assembled but never run and will have some grease residue but it will not affect performance.
https://shop.3dservisas.eu/products/fatboy-mini-drive-train-1-3-for-torqueboards-218mm-trucks
The new FatBoy SS Mini Gear Drive for TorqueBoards 218 and FatBoy 230/240 hangers with custom negative offset wheel hubs for longboard trucks was released
New design features all aluminium enclosure, metal/plastic gears and updated wheel hubs with custom negative offset and integrated mounting plate to reduce the length of the drivetrain. (Normal FatBoy Wheel Hubs or Trampa SuperStar doesnât work wheel hubs require custom negative offset as otherwise wheel hubs would interfere with gear drive and trucks.)
Damn you. Looks dope!
I may or may not have had a small amount of seepage in the trouser deptâŚ
I need a home for a pair of these, iâm guessing they are a snadge too big??
I think they can hit the hanger as the distance is really small
Thats a shame, i would have added a set to my mini drive order
What is the turn radius of that board with this system?
Ahm it depends on so many factorsâŚ
Here is guide for assembly for people who just received the unit
