At the moment dont have exact number, but on mini hanger it fits 2 x 6374 motors without a problem.
Now 8mm motor gear has 10mm lip support for those TB/DarkMatter and etc motors
This was my biggest concern. Not being able to use the motors readily available, still waiting on payday though.
Now available with wheel hubs for Chinese 6"x2" tires expected availability of this drive 1-2 weeks. Pre-Orders accepting now.
https://shop.3dservisas.eu/products/fatboy-mini-drive-train-1-3-for-torqueboards-218mm-trucks
Forgot to mention, that drives are updated, with new gear tooth profile for even less noise compared to previous, less space inside the case for less lubricant splashing, V-ring and other improvements
Pictures of completed new driver will be coming soon
I know its a hard question, but how silent are they?
In my opinion they are same as belts, but belts sound in different frequency range, and gears in different that whats make them bit stand out, as it bit higher pitch deeper sound
But with new upgrades in my next post it should be even less noisier
Finally FatBoy Mini Gear Drive v2 for TB218 trucks now available!
The gear drive now allows to use lubrication, by minimizing available volume inside the enclosure, adding oil filling port, V-ring and stainless steel plates for preventing dust/oil getting in/out of the case for motor mounting/wheel gear/hanger mounting adapter.
Also new tooth profile, for more silent operation and better efficiency.
Also now 2 different wheel hub styles available:
- 3.75" Fits (Trampa 125mm Gummies, 6.5", 7", 8", 7" from Evolve, MBS tires)
- 2.9" Fits AliExpress 6"x2" tires
Do you plan on listing the 2.9" hub by itself?
Itās possible, but there are no matching pulleys or etc available
Gotcha, figured there was a reason! Lol
Itās smaller than 3.75" so normal trampa pulleys would not work
Some photos of 1:3 TB218 on Evo deck in the wild
About time I saw more of these around. magnificent What Trampa tires/tubes are used here?
6.5" Threads
Another discount for FatBoy Mini Gear Drive 1:3 with 2.9" wheel hubs for 6"x2" tires. Quantity is limited
Would this fit on the new Caliber E-trucks with extended axles (w/ 6355 motors)?
Donāt know havenāt tried Would need to measure
According to dimension calculations, it should fit with real 6355 motors But how in real life fitment canāt tell as we havenāt tried yet.
Ok thanks for the quick info
