10S4P 30Q battery (spot welded “modules” provided by @Tinp123, rest done by yours truly)
Focbox Unity
Custom Maytech 6374 motors, kindly sold to me by Timo
A bunch of other stuff that nobody cares about
Credits:
Timo (@riverside.rider) can’t be praised enough. His products and customer service are fantastic. Thank you for sharing both with us.
Also @bigben and @Tinp123 are awesome guys to do business with. Thank you both.
Now to the interesting stuff:
Next on the to-do list:
~Apply griptape
~Finish the belt cover design
~Get @moon to sell some Moonbeams
~Maiden voyage
Thank you!
The motor shaft is D shape and a little longer to better fit existing Haggy components. Also the sensor wire connector is different but it’s under the cable sleeving in all my photos. KV and everything else is as usual I believe.
Thanks! I would have preferred that but couldn’t fit them there. Not without modifying the enclosure or doing something else to the motor cables than using extensions with 5.5mm bullet connectors. This way it was just simply easier.
The space is quite tight down there if you look at this picture.
However I have an idea that I might go through with at some point to change the motor cable routing.
I think the belt cover turned out pretty nice. Still need to order some better (color) filament.
If anyone wants the stl let me know and I’ll upload somewhere.
A bit hard to explain without any pictures or anything but I was thinking of making sort of a wire terminal that bolts on top of the wire shroud portion of the enclosure. It would then house female bullets to easily connect the motor cables.
Probably not so helpful to you at all, sorry about that
Anyway it would still require some modification for the enclosure so not my first priority at the moment.
