Hi! In your case probably 4 75kv would be the best combination. Problem with current design that there are no plug and play wheels that you can add on them. In general if you want to adapt a generetic hub motor you can either make you custom mold like @visnu777 did or convert them to direct drive and then use whatever skate wheels you want. I am converting them to direct drive right now but it’s a custom made project. Otherwise looks to the backfire ranger, skull board hubs. They are using bigger hub motors. Don’t know about power thought.
I was thinking the same thing but I think I’ll go for a custom mold.
When are you going to order again?
Yeh, single set is too expensive. So only in case there is at least 8 sets demand I think it is worth it. I am not sure when we will run another group buy at the moment, sorry
That’s ok I’ll be around when it happens :))
@rey8801 maybe you should open another GB. It seems like there are quite a few ppl want to buy these.
I just realized how messed up your windings look @rey8801… You don’t feel anything strange while riding?
I think those are just normal winding when you hop to the next arm. you can see the same things under the 2 you circled.
But is it normal that they jump 3 arms? Seems weird…
No this is normal I thing. You have 2 classic la configuration delta and wye. Most of the motor a re delta were basically you have 6 wires coming out the stator, with actually 3 phases. In the delta configuration you want to connect a wire from a phase to the other… Well a pictures makes everything easier to understand. Delta is the one on the left.
So the winding you circled in the picture is just the one that goes to the tiger side to connect with the other wires group to make one of the final motor phase wire.
I recently whatched some tutorial about winding a brushless motor and it’s quite logic. Once understood the mechanism it’s fairly easy. For instance a fast modification that 6o7 can do is switch between delta to wye or stars configuration. You will lower your Kv of 1.75 factor. Meaning that Y if you have 130Kv motors and decide to go lower then you will get 75Kv.
Well we can think about it but I do not see that much demand now. I can try to open another GB. Worst case it won’t go through
Yeah it’s 12mm thick It’s a prototype for Ronins and Racestar motor but I never used it.
It’s around 30mm but you have to use it with this inner part.
I have only one because guy who machined it for me fucked up 3 of them until he made this one which is not perfect either.
Since I mentioned in the title is fair to post it here too. Made a thread for it but I can finally try them out!
Holy shit man! They look awesome!
FIY in case you are interested
