No problem. We all have our tired moments. I will try to toy around with soldering on my sacrificial motor before I ditch the soldering idea.
For the love of skatan I canāt get my wire ends clean enough to solder without messing up the windings inside the motor. I am running out of sacrificial motor cable length. I will need to remove the enamel either way, solder or crimpā¦
I tried to use a sharp xacto knife, sandpaper, acetone, none cut it(get itā¦) to a degree I want without causing my further down strands to heat to 180+'C which in turn melts internal enamel and will definitely cause either extreme stiffness or shorts.
Any better ideas on how to(home conditions preferably)?
Could you hold it tight in a vice/pliers and use a Dremel with a cutoff wheel to remove the enamel?
I doubt it. Maybe I could just try and heat through it when I sand off some of the enamel, just wonder how sensitive the windings are on SK3sā¦ Yet on my sacrificial motor I have seen winding temperature of 180āC, gradually creeping down inside the motor and staying at 90āC there. Stuffās creepyā¦
Also - you can take a pair of needle nose or other pliers(or any metal clamp) and affix them to the wire down the line if thereās still enough slack to act as a heatsink so the internal wires donāt get as hot.
The heatshrink will not allow it, thatās the problem keeping me off from using a heatsinkā¦ I could of course try and blow some air with a blower fanā¦
Alright, itās officially time for bed for me. I was wondering why the idea of hestsinking was coming to my mind. I knew I had just recently learned of it. Was it possibly because it was already mentioned in the thread? Yup, thatās fuckin why lmfao.
That aside - I guess Iām really glad I bought maytechs now? My wires are like, nice and silicone stranded haha. I donāt even know what youāre really dealing with tbh
I guess thatās what I get for grabbing 3 SK3s for 35ā¬ each to my doorā¦
Too cheap and brand new to be ruined by bad soldering skills.
With last lengths of wire Iāve found two major tricks.
Cleaning the āenamelā which is apparently some sort of polyurethane (250āC+ melt point) takes just thin pliers with ridges and fanning out the cables.
Flux. Lots of flux. Flux the CRAP out of the motor cables and keep conservative at the silicone ones as that puppy will absorb ALL the solder QUICK.
Anyways, I will try the real deal soon. I have one motor to pop I guessā¦
similar conversation ongoing here
Thereās a link to a cool power tool for stripping enamel
In the end I just went on with crimping, because none of my soldering attempts did it. Mind you, a professional at his field tried it and said that the copper in the windings transfers heat too fast and basically soldering will not form a ālegitā joint unless you burn a lot of enamel in the process. Always a cold/semi cold joint if you go without melting the enamel or stiffening the windings from heat. This explains the 4-5 centimeters of solid solder wicked windings at the bullet connectors at these motors originally:
I used tinned copper ferrules and had to remove their plastic housings(I couldnāt find the uninsulated version to buy). They fit 12AWG and the windings perfectly with space for wire butting left. I also used the crimps on the budget just for that kind of crimping:
These leave a square crimp with ridges and pretty much push all the air out and compresses the cables to insane contact.
I cut windings after motor disassembly to leave ~1cm of uncut winding after the bend, then stripped 5mm of the windings:
Scraped the enamel(very tedious with so little windings, but doable):
Pushed the 12AWG into the ferrule, pushed them together onto motor winding part with as much force as possible as it allows the cables to go into each other, then crimped the HECK out of them, creating a solid joint:
The end result:
This one is my semi-sacrificial motor. A little bit beat up, but itās going with a VESC with 4(4.5?,5?)mm bullets. The standard SK3 ones which I just salvaged from original cables I cut.
The same procedure will be used for my Unity motors. Hope it helps anybody who searches!
Later I might add a little bit more pictures showing more of the process to this post.
Cheers!
Nice!! Very difficult work, having a similar experience myself, but much longer phase leads to work with. Iād love to see the motor IR measurements (maybe even a before/after?) when you get around to configuring your esc settings! Persistence is the only thing that can get through wire enamel apparently, there really isnāt a shortcut.
Thatās for sure.
If unity can spin only one motor during motor detection, I could see the difference in motor resistances for sureā¦
Look at the left record.
Original motor with original leads:
Motor with changed leads:
Both are 168kV SK3.
Crap, I feel outdated. I donāt know exactly what Iām looking at there; Why does motor 2 show 35545mOhms? Am I misinterpreting? Stupid Unity and itās fancy streamlined readouts. So jealous, but so set in my ways. I digress- the left half of your screenshot makes sense to me, but the other sideā¦ IDK
On a side note, as per @deucesdown 's suggestion, The only way Iāve been able to penetrate (lol) the enamel on my mto6880 phases is with a solder pot. A 150W, no temp control, hot as a mother f*cker, solder pot. Having read your post sufficiently to reply here @murloc992 , I know that the pot would not work for you due to the length of your phases and the thermals of copper.
Anyways, looking at the above data, I either donāt have a clue what Iām seeing, or thatās a thousand times higher resistanceā¦? Am I an idiot, or what? What does the red mean? Thanks for the (potentially misunderstood) data!!
The right record is the second motor, which is not connected.
The resistance is the same(even though leads differ in length by 10+ CM), only micro henries and mili webbers are different by one(.1 for webbers), no idea of their impact.
So that means you have a sound and reliable electrical connection I hope? It would be amazing to know if crimping were a viable solution to this!
I was literally ordered to crimp the connections by people who work with all sorts of electronics for more than 20 years. They say if you do it properly, you get a gastight(airtight) āweldā of copper from the pressure.
Heck, I even tried to crimp a phase lead without removing enamel and I still got continuity, I do not recommend doing this ofc, but the pressure is enough to make it(the enamel) shatter.
Thatās what Iāve read too!! Very excited to see your success with that method! Cheers!!
