So I tried hooking up my VESC to a battery and an SK3 motor. For some reason, it just keeps flashing red. The first time I did it, I was able to control the motor with my keys but after holding on to the keys for a while, it stopped working. Did I permanently break it?
I tried changing the battery cutoff and start to suggested values on other forums but I can’t even seem to “upload” the data onto the VESC.
When I read the configuration, this is what pops up.
Yes! I did motor detection and then it started working then after pressing keys for a while to run the motor, suddenly it stopped working. I think I tried clicking apply and write configuration.
Fault : FAULT_CODE_DRV8302
Current : -0.2
Current filtered : 0.3
Voltage : 46.92
Duty : 0.01
RPM : 0.9
Tacho : 7
Cycles running : 3
TIM duty : 618
TIM val samp : 314
TIM current samp : 24500
TIM top : 48373
Comm step : 1
Temperature : 25.37
Current : -0.2
Current filtered : -0.1
Voltage : 46.92
Duty : 0.02
RPM : 1.4
Tacho : 8
Cycles running : 4
TIM duty : 991
TIM val samp : 523
TIM current samp : 22415
TIM top : 43784
Comm step : 2
Temperature : 25.44
Oh no! Does that mean I need to buy a new VESC? How did I toast it? My bad. Would you all have tips on what parameters I should put on before I try running my VESC next time?
