My 1st build used an OG Raptor drive train.
I am upgrading to a set of 100mm Boa’s and want to upgrade from 9mm to 12mm belts.
I am using Caliber 2 trucks that I would rather not modify due to lack of tools/skills.
What pulley are you using on your big kegel wheel builds?
Based in Aus. But I assume I will be buying from overseas.
From what I read, while 15mm is good for heaps of torque, I pretty much ride exclusively in a flat city and it might not be needed.
But thanks for the info, what pulley do you use?
Arha. Hopefully I can work out how to do this without replacing my trucks too. Will check out Dickys stuff to see I would need to mod/replace my trucks.
@vjsharpeyes you should seriously consider a set of wheels other than boas being they haven’t been stocked in many months and people are still waiting for orders from like April or something I believe:
@torqueboards sells 110mm kegal core wheels (use same pulleys as boas) and are a goddamn solid wheel IMO
Thanks for looking out. I actually got a set last year with no issues. Looking at their instagram it looks like they are about to “relaunch” after this quiet period.
