@sl33py: i think it is a APS Mount.
The only mount that I havent cracked is the TB V2 or V3 Mount - the one that is pretty similar to this APS mount but the Motorplate has no cutouts
hm, so after riding probably around 800km with my DIY board it got softer and softer until its finally now too soft in my eyes - the energy returns dont feel as vivid anymore. now sure why that happened … probably laminate bit my bit delaminating? I realized I should have probably roughened up the bamboo veneers with coarse grit before using epoxy to press them together.
anyway, Im just took my DIY board ronin + sk6374 + 90mm stickies combo to my vanguard and man, its such a carving machine. love the longer wheelbase and the energy returns feel very fresh and nice on the vanguard flex2, especially coming from my slowly decaying DIY board. and thats even though the vanguard has WAYYY more kilometers on its back. rode it really long and hard last year. guess the loaded guys really know what they are doing
stickies are coning nicely by now, adds a lot of extra grip. today was sunny, hot tar and Ive never carved harder I think. had way more grip compared to march where I bought the stickies.
Hope your OK man! That big “x” cutout combined with a huge motor is obviously not a good combination. The motor plate should have more meat around the sides and/or Alu 7075.
Oy that’s scary!
Looks like the APS mount really can’t handle anything bigger than a 50XX motor…have you talked to APS about it yet?
I have been using a custome made carbon plate for my alien mount seems to be holding up well sofar.
carbon isnt a bad idea - its probably much better suited to withstand vibrations over a longer time. hmm
this could be my fallback, just ordering a thick carbon plate and cutting out the part of the mount I need which can be done quite easily I guess. until then bruno from APS is milling me a custom aluminium version, thats thicker and taller to carry the heavyweight sk3 6374!
Wouldn’t recommend carbon personally seeing as it has poor thermal conductivity. Probably not an issue if it’s mostly flat where you live but I found my motors to run much cooler since replacing my carbon plates with aluminium ones.
Huh, I wonder how applying thermal paste between the motor and mount would turn out!
The majority would probably get squezed out though.
uhhh, what is this?! a most likely indestructible ronin truck mount with idler pulley by @nowind https://www.e-toxx.com ?!? fuck yea
full set with idler, belt and jens patented mount grub screw adapter that also fits ronin trucks! no immediately obvious aluminium bridges where you can expect breaking like on the APS mounts. aluminium has a perfect milled finish and is really thick!! and incase you missed it: RONINS!
I like the thick aliminium motor guard a lot - 2 of my motors were killed by an impact that bent the outer motor shell where the magnets are fixated!
back to back comparison with my last APS mount after I killed 2 within 3 months now. @nowind mount is made to last, thats for sure!!
Been waiting for those since @nowind first showed pics of it here. But I prefer my Liquid Fyre trucks over my Ronins…and I wonder if these mounts will fit onto those trucks (with minor mods and/or sugru if needed).
That…and these won’t fit 50XX motors D:!
think they fit quite generically … all the mount needs is 2 flat surfaces. jens sent me a slightly adapted ronin truck with the mount!
I never thought about ever using less than 63mm, so thats not really a big deal for me. the downside of generic mount screws is the APS X that broke my mount twice now!
Luckily, the Liquid trucks are square all around, so plenty of flat surfaces to be found ! And I measured my Ronins to the Liquids and it’s about the same, so I think they’ll work…might need to do a little sugru filling in or filing down, but it’ll work!
I was aiming for 50XX motors since I’m not all that heavy and (for now) I live in a pretty flat area with barely any hills. And I was going for a more lightweight build, since 63XX motors are about double the weight (on average).
And I’m assuming you’re beta testing these for Jenso. Keep us updated on how they hold up please and thank you !
ouch. hopefully no gravel rash.
There’s no thread. @nowind has posted pics of them though in the pics only thread. He’s been testing them for a little while now but hasn’t put them on the market yet.
@fottaz also has some pics of Jenso’s build with these on his facebook, because Jenso used his enclosure .
Yes true what @jebe mentioned… Thanks @fottaz for extrem good and fast delievery
@whitepony will do some testing… he is the right guy after killing 2 mounts in 3 month (-;
Got no clue about the price (-; Dont thought about really… But normaly my parts are not for the budget builds…
Thx
Ronins are not really for budget builds. $200 a set in my country. A lot of people will be wondering - how much ! Do you think you would be able to mount 2 for a dual drive ?SK3 6354
cast ronins, not precision ronins! cast ronins are nearly as cheap as caliber/paris while providing a MUCH better ride. set of cast ronins is 90€ in germany!
