So for my first eboard I decided to stick with a lot of enertion parts, but want to find the batteries, esc, and charger elsewhere.
So for the build I have this:
Motor:
http://www.enertionboards.com/electric-skateboard-parts/190kv-electric-skateboard-motor/
190KV 2400W 4-12S (14 Volts - 44 Volts MAX) Diameter 63mm Body Length 55mm (not including axle) 8mm High Tensile Grade A - SUS420J2 HRC55 - Precision Milled Shaft Stainless Steel Axle Precision Bearing Assembly 688Z with dynamic load rating of 1606N Weight 568grams 20cm flexible High Strand count pure copper & silicon 10AWG wires 5.5mm Gold Connector
single motor mount kit and wheels are from enertion as well
trucks are Caliber
So for the ESC I’m wondering if the ezrun 150a esc is good while also using this battery
http://www.hobbyking.com/hobbyking/store/__8586__ZIPPY_Flightmax_5000mAh_6S1P_25C.html
If this is a good setup, how would I go about charging the battery?
