Annoyed with myself. Drilled holes for the space cell in haste, in the dark. Basically off by 1/4in side to side and as a result the holes ain’t lining up. Unfortunately, the holes are too far apart and are going to show.
Oh, and also-- if you’re going to buy your own threaded inserts, make sure they aren’t slot head. About half of them broke. Horseshit
Anyhow, it’s all on now but I’m only using 5 of 8 screw holes. Think I’ll be okay until I track down more inserts.
I used t nuts and epoxied the top side so when u grip it it doesnt show
Yeah I consider this. My deck came pre gripped. At this point I’m okay. I just gotta power thru and get a deck up and gong that I can use. I perfect the art on my second one
I’m about to secure my enclosure as well. I’m really scared i’m gonna mess it up for some reason. I’m more stressed about that then I was about making my enclosure from carbon fiber. Go figure.
How are you going to secure it?
T-nuts seem to be the popular method on this forum. I was probably gonna do that unless somebody has a better suggestion.
That’s a bummer. You could run a strip of LED’s around the enclosure and cover up the extra holes.
most important thing when building up a board? always patience!
