Hey People!
So now I’m turning to this community to gather your thoughts and fill in the gaps I have
As the title says I’m currently planning my board, but before I’ll get into that I really need to give a shoutout to these people for getting my inspirations
Pryside for his monster board here
the foosted board: here
and for controllers: Simple 3D, nano, Smart Remote
So for the project, this is my plan:
Body:
- Vanguard deck (same as boosted)
- caliber II trucks
- wheels
- Enclosures and stuff is still under planning stage
I want to try to 3D print as much as possible so the motor mounts and gearing STL files are something I’m looking for (I might CNC out the motor mounts in aluminum) - would love if you have any good links or models
So I’m planning to do a single motor set up to keep the price down and I can always add another one later!
But now for the part where I need help!!
I’m planning to build my own controller as you’ve seen earlier but I’m not a hundred percent when it comes to certain things: I’ve fallen for the smart remote because of the bigger screen, layout, and features like ESTOP, but I’m having a hard time accepting that it talks over 433Mhz instead of 2,4 GHz, what are your thoughts here? Should I try to modify the Simple 3D remote instead and get a bigger screen and try to use the same firmware as the smart remote? Does anyone have knowledge of the battery in them? Maybe to try to build one with the esp8266 instead?
And now for the receiver, is there any specific VESC I should look for and maybe stay away from? I’ve been looking at this one and this Both of these shouldn’t have a problem with me building my own remote right?
I’m planning to build a 10s2p battery since I’m happy with 10km range, but the question is if that’s a safe setup since if I build the battery with samsung 25r batteries I have a safe max continuous discharge rate of 40 amps but the motor (alternative) has a max amp of 80 amps.
Should I aim for a 10s3p battery to be on the safe side? I don’t live in the hilliest area and in Sweden, so it’s not boiling hot in the summers. I’m also considering too fit it with a smart BMS as Pryside did in his.
For the motor, I’ve been looking at the ones linked above but I’ve also looked at this one. Thoughts? are there any advantages with higher KV other than speed? I’m not looking for a board that goes over 40km/h, 35-40 is a sweet spot I think.
So my biggest concerns right now are with the electronics. I want to make sure I’m building a reliable and good setup, that my VESC and remote, battery ESC, gives me the best riding experience!
I can always go more into detail how I’m going to design the board if there is interest!
What are your thoughts? everything is appreciated!
