I have recently completed a build and I found the performance a bit underwhelming. I decided to optimize the vesc settings so I tried to connect my vesc to my computer. After a while i got it working so i decided to update the firmware. After this was done the board stopped working. It turns on but nothing happens and the remote controller connects. I dont get the same three blinking lights before i connect it to my computer. Right now i am basically stuck with a board that doesn’t work so any help would be appreciated. Another thing to note is that when i tried to measure the L&R the board shut of after the motor made a sound, everything is fine and nothing got hot.
Edit: I have had this thread up for 12 days without any response so i would really appreciate any help possible.
That should be based on hw 4.12
You choose the wrong hw version while flashing firmware
You can see it, it’s written 48
But there should be different versions be available.
You need the one which fit to hw 4.10 4.12
No problem.
Where you got the software from?
I mean where you downloaded the vesc tool?
On your picture you sent i can see that the right firmware not in the vesc folder.
Unfortunately I don’t know which folder it need to be (name and ending).
So, my easy way would be,
Ask here in the forum, or uninstall the vesc tool,
Go on the official vesc homepage and download again the service software.
Than open the vesc tool. Under firmware there should be not only 48, also 410,412 and some other hw should show up there.
Try this. If that‘s not functioning let me know.
I’ll have a look where to find the files.
