Hey man, you came here for critics right? You don’t see boosted on these forums cause they would get chewed, spat and chewed on again for their shit advertising. Heck even onloop gets crap for his poop advertising and fake specs.
If you want honest criticism, then I’m giving you some. Your board cannot do 1400W continuous. If you want to be just another e-board brand with exaggerated specs then by all means, say your board can do 1400W continuously, but dont ask for honest critics if you want it sugarcoated.
E- I will be adding a few edits to respond to specific parts of your post.
Yes, key word being peak. They don’t advertise the car being able to sustain that horsepower for the whole ride, which is what you are suggesting.
Agreed.
Here is the main difference:
Can your board do 1600W? Definitely no doubt.
Can your board do 3200W? If the ESC and hubs can handle it, then absolutely.
Can your board do 4500W? Again, if the ESC and hubs can handle it…
Can your board do any of that continuously?
That would be a big fat negative ghost rider
30Qs are rated for 15A continuous in free air. After that they are rated up to 80A as long as you keep them under 80 degrees celcius. Yes, you can drain these bad boys at 80A each as long as you keep them cool. Does that mean your board can do that? Maybe for 2 seconds… but definitely not continuous.
If you want to advertise peak power, that’s fine! But that is VERY different to continuous power.
Yes! Definitely! But not for 45 minutes! That is the whole point of the word continuous.
It’s not theoretical, its a real limit. If you advertise it as 1400W continuous and I test it to 1400W continuous until the battery is flat and it catches fire, who’s fault is it?
It’s also not average power. It’s continuous power. Again, peak and continuous are very very very different, which is my point…
Is it useless and self-harming?
If you tell me this board can do 700W continuous and up to 1500W continuous for 5 minutes. I would be impressed.
If you tell me this board can do 1400W continuous then I will call you out and move on.
BUT and this is a big but, I AM NOT THE TARGET AUDIENCE. You are targeting people without any engineering background. In which case you kinda have to lie about specs, otherwise you do not stand a chance against others that do
