So…4wd eh?
Extra $370 with discount of 10% equating to $74 of total, basically send another $296?
Tempting inducement, but ye cannae do this between pay checks friend
So…4wd eh?
Yup, you are right! If you already put an order for a 2wd, then you’d only need to top up accordingly! (:
It’s like free trucks!
@nuttyjeff sorry if you already answered this but how wide is that POM gear? 10mm? i see that you have already used it for 500km and im trying to decide if its strong enough for a gear drive for my own project.
It’s 15mm
is that the face width? or including the hub?
Yeah. Just the face width. Do note that there are MANY other factors that contribute to the strength and durability of a gear - What works for my setup might not work for yours, unless it’s somewhat identical.
Is this still available. When are you expected to ship?
Yeap. Simply fill out the google form! Manufacturing will begin in march and should ship late march to early apr!
https://docs.google.com/forms/d/1gYr1-n0KrREdRcyXWUtRPM9gcydkQm_xFLcjo0lM4Ak/edit
If you’re still taking names I’ll go another set please, payment to follow end of Feb, thanks
Haha sure sure. Just fill up the form. Ill be taking orders through the whole of february! Will put you in for another. Do edit the form when you’ve made payment (:
CNY is coming to end and manufacturing can start soon! Hooray!
Edit: @Linny pointed out that trampa uses a 12mm to 8mm spacer to ‘convert’ 8mm axles to 12mms to fit their wheels. I’ll check it out!
That’s all folks!
I currectly have the Trampa superstars with the 5 bolt star pattern, but i do plan to buy the kahua trucks and Bergmeister wheels specifically for this kit… but if there is input for wheel adapters itd be cool to have the option use this kit on my Trampas.
I am using the bergmeister wheels and already have the haggydribe system. How much for just the gear drive?
The price of the gear drive does not include the bergmeister wheels or the trucks. It’ll still be at the listed price - 370usd
Would you recommend this stuff to seal the holes for the ‘holy’ trampa line?
I realize now that it would have been better to just get the regular deck… But I doubt Frank will accept exchanges.
It’ll probably crack from the flex of the deck
Heck.
Thanks!
So my board is already pretty heavy around 30lbs. The handle is a blessing because I almost dropped it before it’s just so unwieldy.
What is the weight of the whole gear drive system? Compared to the haggy mounts and belts what will be the added weight?
I wont be able to give you the difference in weight (I don’t own a set of the haggy drive myself) , but I will weigh the drive (motor mount, cover, adapter, gears) and get back to you on this.
