Then it would hit the belt
ah yeah true
arrived perfectly, bombproof packaging, stoked base plate. DRAAAANG!
Oh man… think i know what im ordering from surfrodz next.
Adjustable base plates?
Smaller hanger tkp first. But im not seeing a 149mm in the tkp hex 10mm axles. I saw 177mm or 127mm. The tkp hex 8mm axles have 100mm 139mm & 159mm. But I’d rather run 10mm axles so i can get longer axles for pully bearings.
I think the 127mm will work tho. @drangboards do i NEED adjustable baseplates both front and rear? Or just rear mainly?
Says so on the box:
Edit: ah, maybe it’s only with 8mm axles
You need a low angle is all. Depending on what your building deck wise
Rear only is all
I can almost buy trucks and a single adjustable baseplate for what it would cost to order from there. I think 127 will work tho. I can buy those direct
Are there any left I would like to buy.
I do believe I might have 3? Still need to get one out for international shipment.
Ok would you be able to hold a 23 for me I don’t mind what Color
I would like to buy a 23 baseplate. Please respond to this ASAP
I have to get a few out, and then let’s see how many are left after that.
Could you please tell me when those baseplate arrive.
? The eagle has landed. Last week. I Might have 1 or 2 left.
Do you have them with You now I need 1 before the start of race season.
