It has just dawned on me I may have made a small cock up, i have been referencing this great drawing from i think @mmaner
I appear to have completely ignored the charge wire dept.
Can I tap the positive onto the main wire or should I uncover the + on 12s and go direct? I’m using d140 charge only…
I’ll be using a meanwell 4a charger, what gauge should the charge wire be?
That’s all good, the balance wire carry very little current < 200mah. As for missing the charge port lead just connect it to the positive wire, preferably before the as switch as you won’t have to turn the board on then
IMO 26awg is very delicate, and has to be handled with extreme care especially near the crimps. OTOH if you have a short somewhere because the wire broke, it’ll have a very good chance at acting as a fuse and burning itself out before anything more serious happens.
I’m with Pat I like 18awg. Pick something thick for robustness, as long as its not too thick for the connectors.
Guys I’ve done my first p group. Fish paper rings on both pos and neg and a full fishpaper wrap around he cells. I don’t think I’ll be getting any shorts this century.
Need some more opinions. How do you feel about a single layer of 10 x .15mm nickel on the parallel connection? It will be linked in series with 14/12awg
