Are you talking about this set?
diy-electric-skateboard-kits-parts/36t-abec-drive-pulley-belt-combo-kit/
Because I am not sure that the bolt would fit in between the spokes. Also would it be easy to find nuts to fit those bolts in the US?
Also, I would be using a turnigy sk3 motor which has an 8mm diameter shaft and the specs about this motor pulley aren’t listed. It also doesn’t come with a grub screw or key so I don’t see how you attach the pulley to the motor.
If @Jinra you think it wouldn’t be a huge mod to the wheel or the pulley, then I will stick with the exertion set but if you think otherwise, let me know
The old pulley required you to driller through the wheels so the bolts would fit. I suppose you can do the same for the new enertion pulley, but I’m not sure how well it’ll work. I don’t have flywheel clones with those types of spokes so it’s anybody’s guess!
Actually, taking a closer look at the wheels from enertion through Jason’s videos, there doesn’t appear to be any cut outs like in the abec 11 ones. Wouldn’t that cut out be covered up by the bearing anyway?
Report back with your findings! Someone on the Evolve thread said the evolve pulley didn’t fit their 97mm clones due to the fatter spokes. However, Enertion’s pulley is thinner so maybe it’ll fit all flywheel clones.
Sorry to keep bothering you @Sean555 but you did mean to say the 90mm wheels right, not the 83mm ones? Cause just got another e-mail from enertion support saying the pulley is made for 83mm wheels. But if you are sure they were 90mm then I will take your word for it
I will post the rest of the mechanical build and the electronics will be posted after Christmas as I will be asking for most of the parts for Christmas
