Alright, after a lot of time talking to some esk8 wizards, I have reformulated my plan a bit.
I am planning on using a Landyachtz Switch 40, with torque boards 218mm trucks, and MBS 100mm All Terrain Wheels. I currently have 1/2 inch risers on, but may have to add another 1/4 inch on.
Under, I will be using 5x 2s 5000mah lipos, going to a 10s Bms as seen here; http://www.electric-skateboard.builders/t/high-power-10s-lipo-battery-pack-with-bms/10014
I am using a single Turnigy 6374 192 KV motor with 15/36 pulleys in the @marcmt88 full drivetrain kit.
I will be using a VESC, most likely this one to save a little bit of money; products/torque-esc-bldc-electronic-speed-controller
I will either be buying or making a slim enclosure, haven’t decided yet. I also an undecided on transmitters and other components.
Am I missing any thing that will cause this build not to work?
