I got tired of waiting for my Raptor 2 to arrive - will it ever? - so I decided to go all in and build my own Electric longboard, to keep myself busy, and in the process (hopefully) get an amazing board that I can fix myself.
Full disclaimer: My parts list has drawn quite some inspiration from @sk8l8r’s Clone Evo.
So you are saying that the BMS switch acts as an anti-spark switch in itself? - Because the battery I am buying comes with an external on-off switch that’s attached to the BMS.I was curious as to what that “BMS switch” actually did.
Regarding the wheels - great suggestion, just replaced the wheels
Updated to KEGEL type pulley system. Currently looking for a european vendor that sells 36T pulley drive-trains in metal.
I could most definitely be interested in a custom battery pack, should there be a european builder willing to do a commission for me. That also goes for enclosures. @pjotr47 and @bigben - interested?
Again thanks, moon. Man, I wish I had checked this forum earlier, what a great community!
I checked his site earlier today (https://shop.3dservisas.eu), looks like solid quality machining. Unfortunately his selection is somewhat limited currently, there’s no 36T or the one connected to the motor, forgot the number.
The motor mount I’ve selected should allow for tensioning/loosening, so as long as I get the approximate belt ordered, I should be good. The https:// kit comes with 16T/36T and 265MM belts, so I’m going to order 300MM belts, possibly also 320MM belts.
Edit: Updated list with new transmission system.
Re: @moon 36T: you don’t happen to also have a 15T motor pulley? Otherwise no worries, I’ll just order from websites.
I do an enclosure for a single stack and I can get a 10s5p with large bms in mine. I also have some of the decks that @moon was talking about.
You can see what I’ve been making here.
https://www.instagram.com/bbenclosures/
Good luck getting your motors fit. I’ve seen it done but on my Evo falcon with eboosted enclosure and caliber 2 44 degree trucks I had to do reverse mount. I had the same mount you have listed and had 1/2” riser.
