Okay, So the “thick” portion is the the wheel hub itself not the studs on the stl, that is to say the “thick” hub STL version has a stud that is smaller in dimensions and will fit into both the original “Thin” hubs as well.
I’m using your STL file from here as the mating portion of the wheel pulley. I cant actually “use” the file itself but I spent some time and made an exact replica of everything but the pulley itself. Now I’ve started the process of inserting the pulley from another source file and merging and doing the 9, 12 and 15 mm versions. I tried making these from 32-44 but 32 is too small. The nuts would mess with the teeth of the pulley so I’m doing 34-44.
Sweet! Yup. 32t will probably only work on the Kegels. I actually got the adapters from here, if you wanted to use the originals instead of the one I modified.
Sorry, that is the link I meant to reference. I do have a question though. Since I dont have a wheel in front of me I’m kinda flying blind here. Can you tell me what the diameter of this edge is, where the conical part meets the back of the wheel?
Thanks. Thats fine, they should be similar enough. Just want to make sure the 42 and 44 Tooth pulleys will actually fit before I go ahead with anything start uploading things.
just go to the hardware store, take the pulley with you.
5X 10-32X2.00" Bolt (or 10-24)
5X 10-32 Lock Nut (or 10-24)
Alt: 5X 10-32 Nut (or 10-24) +Loctite Thread Locker if you dont have access to lock nuts.
5X #10 Washer (optional, to be placed between bolt head and Orangatang Kegel Flat Face Adapter)
the 21 and 17mm disks are just as a reference so you know how big your axels are. you;ll need a minimum of 21mm clearance if youre going to use the hux nuts on the backside . thats all it is. if you have caliber trucks you’ll have to file down the edges, if you have paris or others you probably wont been to. you could also put socket head cap screws in from the backside and that will reduce the clearance you require
Hard to say, I’ve got I set I’ve put 150km on with no visible wear. I’ve got another set with only 1 long run, around 20km. Also no visible wear. I’ve heard 300km, but for whatever reason I just don’t see that with mine.
