Hey octof1sh! Thanks for the compliment, and I’m glad you liked the board. It was really fun being able to ride it around the faire
It makes me wonder if the should be an esk8 builders meetup in the bay area or something… There’s was quite a lot of us at the faire. Anyhow, feel free to drop me a note or post here if there’s anything I can help with in your endeavors.
tell me please the base ESC on ONAN is it vesc ? I wanna make some hack like you but i place TORQUE Single Hub Motor (collections/electric-skateboard-hub-motors/products/torque-single-hub-motor) so i wanna know what the type of esc and battery be better
If the ESC is the standard chinese one (meepo, woogo, ownboard, backfire ecc…) and I am afraid this is the case, no it’s not possible because it is not open source. You can either replace it with 2 VESC (dual hub at least for onan booster, right?) or in order to save money now the chinese companys had released a new ESC that seems having a smoother acceleration and brakes. Depend of what youare looking for and the budget available.
Hi Faust, (and others) I just got an onan (labelled as nuff board) and it has a dead controller board. Is anyone who has gutted their onan unit willing to sell me their old controller pcb? I believe the big board in mine is ok it’s the daughterboard that is fried, so even if someone’s main pcb was damaged I could probably still use it. I’m in northern California… Thanks!
UPDATE: I got VESC controllers instead. I actually wrote to ONAN in china and at first they offered me a new control board for $85 but then started to bait and switch me up to $345 for everything including shipping. Real rip off, so I went VESC instead
Unfortunately not. The cables are low-current and I believe the ESC wouldn’t supply enough current anyways. You’d need to swap in 2 VESCs. There’s also the clearance issue (since the AT wheels would have wheelbite on the chassis).
I managed to do this by moving the chassis forward, but it was basically a full overhaul.
