The spot welder arrived on Thursday. Finished the battery and did some documentation for you. More soon…
Frank
Frank
Hell yeah man great work
This is the finished battery - balancer leads still need the JST connector. I will do that once I made my final decision how to rout them. The positive poles of cell groups are marked red. The individual packs are rock solid, housed in a 2mm Tufnol shell. The Tufnol shell is glued onto the cells with Pattex. Cells are glued to another with Pattex. Pattex stays flexible when hardened and is dam strong.
I wrapped the perimeter of the cell groups with 1mm polypropylene strips. The centre spine is bolted onto the deck with 2 M4 x30 countersunk stainless screws, locking the battery back in position. the Spine is a bit prone in reference to the cell groups. Balancer leads are a bit longer than necessary to allow the flex - other wise they would stretch when the deck flexes hard.
Final space inside Housing: 60.10cm. Enough to fit 12S4P and two VESC 6.
The “End Bungs” from PVC L-Profiles are now reversed - the lower branch of the L faces towards the trucks. This gives me a bit more space on the inside.
I will post a complete walk through next week. After that I will do the wiring, truck mount, grip tape, M6 Inserts for bindings (top mount, detachable).
Once I have finished the build, I will mount 7" pneumatic urban wheels, 90 mm Stickies, 125mm urethane wheels and I will do a infinity MTB hanger upgrade, using 8" Pneumatics ( full MTB setup with bindings).
4 in one Board…
@DanSkates: DRS capable! No worries!
Frank
Hey trampa did you get idea from the Buffalo board that bends?
@trampa very nice tape u got there for wrapping the batteries! Could u shed some light on where exactly did u buy it?
It looks like ‘‘ductile’’ tape to me… and probably ‘home depot’ shops have something similar…
so is it just ‘home depot’ reinforced tape or something more special?
Does look very good when batteries are wrapped up in this black tape
Tesa Tape!
The wide stuff is a sort of Gaffa tape.
Frank
No, its pretty obvious you need to segment stuff if you want the flex. The slitting pattern is nothing special, its just that you overlay two patterns and shift them to the left and right.
For an MTB I would only drop in the slits on the side of the Box.
Frank
Sorry for the delay BTW, due to a shit storm I couldn’t really focus on the Board. I think now there is less brown spray in the skies and I will continue to finish the HW and post everything.
Cheers, Frank
Wer bist du, Mann?! You keep everyone waiting
Well, we moved our business last weekend, went on a holiday with my family and tomorrow I’ll fly to Sweden to help Benjamin a bit. He had an accident and can’t stand up. The board needs to wait…
Frank
Wow! Seems like you’ve really got a LOT on your head now! And I sure do hope all turns out all right with Benjamin!!! Wish him a quick recovery from us here!
I just started my Street Carver build and I’m closely following some of these procedures but not all of them, however I have several questions:
Why have you done a center wooden back bone?, it won’t add rigidity to the battery modules or protect them against impacts at all, well maybe just if the impact is on the dead center but the majority of impacts should be absorbed by the enclosure itself.
Why did you mount the battery in a horizontal array, the flexible cable needs to run diagonaly between packs, stressing the nickelstrip, specificaly on this particular spot:
I don’t get why you didn’t mount them horizontally and just connect each pack with flat cable.
Sorry for all the questions, I guess you have a point for all of them, just need to understand why are you doing certain procedures
The wooden back bone: The Box is very stiff at the edge, but in the centre it can flex a bit, since its a flat surface. The wooden back bone will prevent hat the centre of the box can deform. Edge, Center, Edge Suport!
Cables: The cables twist and swallow the deformation in torsion of the cable. Works a treat. My Cable is very very flexible, 1036 Strands
11s4P: just as good as 10 or 12S, 13S Why not! There is no reason to go for straight numbers and I want to have the space to experiment with a BMS, and other devices we plan to make in future.
Frank
I should some time this week to move forward on my build !
@trampa Frank, what distance between splits did ya use ? are the cut lines based on the 4P 18650 blocks connected to each other ?
I’ll measure that out for you. Box is 61cm I think and slits sit in a regular pattern. Basically I just divided the length by the segments. Easy…
got it - thanks.
I think you only need the small slits in the side. Give this a try first!
Frank
How are you charging 11s and are you using a bms? Most chargers and bms are made for 10s or 12s
Hey, Frank! What length M4 repair threads have you used? Because on their site there’s like a million options (or to be absolutely exact: 5 options :P) Thanks!
8mm is fine =2D
