At this point I think it’s actually something in how the app handles data received… but that could change as I look into the issue. It may also be an issue of the Unity mcu being overtaxed by the amount of polls the app does of the Unity.
250k baud rate too high for the Unity?
I read in the metr thread this might be the problem.
I prefer to ride by used mah instead of voltage. My graphene lipos keep the same voltage most of the ride until the end where they drop suddenly.
I heard Enertion is going to come out with an app with their Unity. Example for setting of the motor adjustments from your phone instead of connecting to your computer. Or is this app just going to be monitoring your trip, odometer, and keep charts with the following info so far on the app?
This is the new Enertion app. You will be able to configure your Unity here as well as stated in the description.
Ok thanks! Here we received the New Lime Scooters and I tried one out. Basically same as electric skateboard. I heard some cities are frowning and are making electric skateboards illegal in some parts of the world. Since you’re in the process with this app maybe an option on the app can be role/kick assist. So if you turn the feature on? All you need is to role couple km hr then it engages power to the remote to run the Unity. At least it can be used in an argument if getting a ticket. Here as long bikes are pedal assist and scooters there ok to ride. Also a speed governor can be selected. It’s just an option and proof since you app will have ride history. Kick assist only when at an initial stop and ready to power the board.
The app won’t add features to the Unity, it’ll simply allow you to access and configure the Unity’s existing featureset.
So far so good, thank you so much
So far it’s been great, it disconnected once during a 16mile ride, but was able to reconnect after closing the app and reconnecting it. It was after about 30 minutes of being connected, it didn’t do it the rest of the ride.
Again, thank you for everything sofu
So there’s actually an upcoming Unity update that will fix the telemetry deprioritization issue. I’m hoping that will be the fix needed.
I’m glad you like the app so far, there will be an update this weekend for tracking + telemetry. Keep an eye on Testflight!
Thanks, I’ll have another 100-150 miles logged in by Wednesday.
Well it seems my sunday will be wasted reinstalling macOS. Unfortunate…
Any chance, that you will support Tizen OS smart watches (samsung smart watches ) ??? Thanks
No unfortunately
I downloaded TestFlight it says I need a redeem code
After you download TestFlight, go back to that page linked and click on “Step 2, Join the Beta” and you should be able to download it
make sure you’re doing this on your iOS device
Looks like @hotdoghelper is helping more than just hotdogs
