Alright, here is the drivetrain @Mikeomania12 and I have been working on for a little while, which I have appropriately titled: “The NYC Drivetrain of Death”
Best run in a dual diagonal setup, but can work in a regular single drive if necessary.
Here are the specs:
Custom Steel Motor Mount
20/36T Gearing
245KV SK3 Motor
I run this setup at 6S, Mike runs his at 8S. A dual setup is important for getting max acceleration using this setup.
Other than the steel motor mount, nothing. I don’t hear about setups with 20 teeth often though. I posted it because I was recommended to. It’s also just a sweet setup, and an easy way of getting good speed.
Yeah, I have seen those parts before but at least I don’t remember seeing them together in a single configuration.
20T/36T/245kv. Can you tell us more about performance?
Don’t see many 20T motor pulleys, would be interested about how that makes the torque vs speed trade off as I am moving in the other direction, larger wheel pulleys + wheels (44T/197mm) and smaller regular motor pulleys 15T.
Surprisingly functions pretty well. The only issue I have run into is with my ESC, if I try to bring the motor up to speed too quickly, the ESC will cut out. Must have to do with a current limit or something… The torque is fine, even on single-drive, but I would say that may depend since I am VERRY light. You should come by and try it out for yourself! It’s a lot of fun!
With 83mm wheels that should be 24-28mph, and if your system uses 3kw (reasonable estimate) that’s only 70A per motor at 22.2v. With the right esc’s this should be a really solid system. I wonder what the brakes feel like at 10s.
This topic caught my eye. I just registered, but can’t figure out how to make my own posts. I’d like to share my very own drivetrain of death…36aH of capacity, 3 batteries and 4 motors in AWD configuration. Yours is much more elegant and functional. Mine is more like a battleship
@erikorjehag The pulley is from TB and has one flange removed since the wheel pulley already has an inner flange.
The steel mount is something I was forced to make because all my other mounts (TB all versions, and psycho) of 6mm thick aluminum kept snapping after short periods of time. Not sure if they are too thin or maybe aluminum is too flexible, or maybe this gear ratio caused too much stress on them. If anyone wants to try them I had a few extras made.
I’ve been running this drive train setup on dual diagonal for almost a year now.
97mm wheels on 7s a123, 245kv 20t/36t ratio
Regarding the speed, torque and efficiency of this setup:
Speed:
comes to 38mph max
its very fast!!
it doesn’t like to go slow…difficult to maintain walking speed with this gearing.
Torque:
For my weight (150 lbs) i need a dual motor to make it ride-able. it has no torque with just one motor. it constantly cogs and takes forever to get to a usable speed to stop cogging.
For @michaeld33 luckly hes like a stick figure so one motor is good enough lol
Efficiency:
Not the most efficient gearing. Especially with just one motor the it pulls crazy amps and gets very hot. you will need a very powerful battery capable of high current with thick wires everywhere.
With 2 motors it is a lot better. Basically no cogging unless I floor the throttle from a standstill. and even then the wheels usually just start skidding and burning the pavement lol. The system runs warm most of the time. but after riding fast and hard the sk3 6364 (which is actually closer to a 50mm motor) get too hot to touch and i can fry an egg on the outside area of the enclosure where the ESC is located inside. I am using 6s hobbyking car ESC with the fan on it and its been holding up very nicely. I would never recommend using the VESC here it would melt in a second
I just recently switched to better motors and they are actual 63mm. They barely get warm even after hard acceleration.
The ideal setup here for mono-drive is probably 15t/36t but me and @michaeld33 did this kinda spontaneously one night and were limited to the parts we had on hand. My 15t pulleys were only 9mm and I didnt have anymore 9mm belts so had to settle for 20t 15mm pulley. but he got lucky cuz hes light
Hey Mike! I’m interested in the motor mounts since i’m about to build another board. They are made for caliber trucks right? I’m willing to pay, of course. Let me know. How are the flywheel clones holding up? I’m about to buy some 83mm ones. Thanks!
Hey Tomi! Yes I have some. They are for caliber trucks and fit almost exact though you may prefer to put a little shrink tube in between to make it more snug. They cost $60 each. How many you need?
The clones kinda suck. They are hard and vibrate alot especially 83mm. Also i’ve had 4 cores crack on me with those wheels. clone wheels should only be a temp solution.
I would get some real flywheels. If you get clones go for the 97mm because they will feel smoother.
