@Narnash thatās interesting because itās let me post a for sale ad, I just canāt reply to other peopleās adsā¦ āSTATS 31 days visited 3d read time 978 topics viewed 23.4k posts read 194 likes given 3 topics created 107 posts created 76 likes receivedā Pm is fine. Iām on here reading a few hours a day so Iām sure Iāll get the privilege soon enough
Okay thanks! Iāve also seen a lot of people make it the same way, so that should be able to do the job. If my calculation is right, then will there be able to go 4*13,42A=53,68A (nickel strip is hot) through each series connection. Lets say I set the maximum battery amps to 30A. Will the VESC then ask the battery for 30A and take 3A from each parralel group to make the total 30A? Cause then i technically only need 1 nickel strip on each series connection?
.15 8mm wide nickel is really only good for 7 amps so instead I recommend copper for by our serial connections
Okay. This shows that one 0.15 x10mm nickel strip should be able to do 10A with no problem. Im going to do 4 nickel strips on each series so that should also do it.
Plus the shorter lengths can handle more current. That diagram is for long length of strips.
guys I am a bit in a brainfart can you help me with calculating:
If I have 6inch pneumatic tires, what kV motor do I need to get up to 45km/h without any gears between the motor and the wheels? Thank you
How are they going to move without a gear you would have no drive system with a gear
That doesnāt matter, maybe I go hubmotor and maybe i go belt but every different kv needs another gearing so its handy to know the needed rpm that tge wheel will have
Good luck finding a hub motor for a 6 inch wheel. The gearing you use has a direct influence on the speed you can do same with size of the wheel. with a 6 inch wheel and 16-42 gearing you could on 12s li-ion you could use a 140 kv motor to get 56 km/h weighted
Direct drive is 1:1 ratio
yes that is a smart one I can just use an esk8 calculator haha
Hey guys. I have a question about batteries and antispark solutions. I ordered a Torqueboards 12S4P battery that comes with an LCD screen, connectors, and a switch. I also ordered some antispark XT90 and XT60 connectors to make a splitter that gives power to 2 FOCBOXes. My question is, do I need any other form of anti spark protection? Or am I good?
You should be good. Pretty sure the BMS inside the battery does everything for you. The only thing you have to do is connect the battery and have fun good luck!
Awesome, thanks for the help!
hi, I am trying to decide if it is worth it to upgrade to 12s4p over 12s3p. I understand that this would change the max continuous current to 60a vs 45a. would this give the board noticeably more torque and a higher top end speed?
I donāt think it will give you more torque or higher top speed. But it will give you more range and maybe even less voltage sag. I donāt know about the last one. I would choose 12S4P since I hate running out of juice good luck!
Dumbest question by far!
On my DIY Trampaboard, I have a 12s4p battery with a BMS controlled by a simple toggle on/off switch. The only problem is that the battery wont turn off - its not responding to the on/off switch suddenly. It used to work, but now it does not.
Is it possible that if the polarity of the charger input was swapped, that might result in this?
Any ideas? Please respond ASAP, since my board is slowly dying! Thanks
If u havenāt purchased it yet Iād be curious to know more about ur build as I may be able to offer you a larger size for same cost if ur interested
If itās a 30q pack you can do 60a now. The benefit of more amps is less sag which equals less high amp drain which adds a lot more range, more than 25%.
