Hi everyone
Im going to make a 10S6P samsung 30Q battery but I donāt know how to weld the pack together. I have two options. Which one is the best? Maybe why? Any other suggestions?
OPTION 1:
I use 10mm X 0.15mm nickel strip. If there are two lines, that means im putting 2 nickel strips instead of 1. (not my picture from the side view)
OPTION 2
I use 10mm X 0.15mm nickel strip. All the read lines are 2 nickel strips on top of each other.
You āshouldā be good. I qualify that because every switch Iāve ever used Iāve burned up in hours or days, Iāve had a Luna 120a switch running for a week so thatās a win I guess .
Thatās cool. I donāt think Iām running that much amps anyways.If switch gets burnt up, the board will just shut off without damaging the battery or VESC ?
If you have ever worked with epoxy it gives a little but not much it is what the use on carbon fiber decks. Depending on the type of plastic and how many layers you use with determine how much flex there is.You would have to fine a epoxy that works with both plastic and glass. Any type of glue works best with a porous material maybe besides JB weld that stuff stick to everything
You have to be a āregular memberā to do that. I donāt know the exact requirements but I think your account has to be 100d old with decent activity to get that.
Itās a safety feature of the forum to stop spam bot selling offers and genral scam.
Try it with a direct private message to the seller, that should work.
I registered so that I could make wanted ad.
I am looking for:
-Used Holypro 16 ply board with vertigo trucks and superstart hubs. Any color parts is ok.
-Used E-toxx mini direct drive. Any color is ok to me but black is what I want most.
There is no way of making this ad before 100 days has passed?
I also have some parts that I could sell or trade.
@Skunk@anon76406330
Apparently I was a tad wrong, to buy/sell or participate on any group buys you have to be a level 2 member. The requriements to get level 2 for your account are:
visiting at least 15 days, not sequentially
casting at least 1 like
receiving at least 1 like
replying to at least 3 different topics
entering at least 20 topics
reading at least 100 posts
spend a total of 60 minutes reading posts
