Evolve Carbon GTā¦sorry
Ah Iām with you. No mods necessary. Itās just a plug and play between your battery and esc. What connector is on the battery and what connector is on the esc? Pics if youāre not 100% sure
Its hard to see but its a weird proprietary connection not xt60 or 90
What is the fastest speed you guys will go on surfrodz TKPs?
I wanna see if my gear ratio is still to high
If you know how to solder, itās not hard to swap connectors out. Battery connector looks weird. You could look into existing anti spark switches but many use xt connectors as well.
cool i plan to swap this Evolve ESC out with a Unity would I still need to do this?..when i plugged it in i noticed the board was powered on. Do you think that had something to do with it?
Could be. Unity has built in anti spark. I have one and can confirm it works great so far
Where do you live? I have seen red boa somewhere. Anyhow the wheels you posted are abec core. You have to see the internal core. Kegel or abec. Now day mpst of the people want kegel, but I am also using abec. We can make the adapter for both no problem. For Abec I would look into abec 97 mm s black superfly.
12s3p is smaller in size than 10s4p it will fit no problem in the deck, donāt worry I am using 12s3p with 30Q and with this motor is giving me 25km at least. I donāt know how much range you need.
I live in The Netherlands.
Where did you find it? Everywhere I looked the wheels are < 85mm, or have the ABEC form factor (and most of these are also out of stock). This is the only one I could find with boa wheels, but itās out of stock (both colors).
Damn, I thought I checked :/.
I donāt have a preference, any other than that I must be able to buy one. If the adapter works for ABEC then thatās fine, they seem to be better in stock anyway.
I know they can fit theoretically, as there are 4 less cells. But Iām wondering how you would lay out the cells given the problem before.
I was thinking 25 at least, with hopefully a little bit of extra in case of headwind (itās The Netherlands after all). There arenāt any hills, so that does not have to be taken into account. My goal it to get to my work reliably without having to peddle the last 3 kilometer. That is 22 kilometer away, on pretty much a straight road. Of course Iām able to charge up the board there.
If you have a straight 22km 12s3p cna probably do it if you donāt use it at 100% speed all the time but I do not like to discharge so much the battery so maybe 4p is better. Are you sure can not fit at least 11s4p in the deck? it has pretty big grooves. If I have time I could model it or maybe just try it in power point to put cells with the right size in the chamber (measures are published on the thread) and we can see it. If you use unity that is dua and small, no need of antispark because included. Small charge only bms like Bestech D140 (good one) should be totally feasible. To me also 12s4p. What you say about the layout itās only because you didnāt try to draw it. If you have different number of cells in one chamber compare the other doesn;t make any difference. I also do like that. You can check my integrated deck (Bullydeck is the name) I am making that use similar grooves in size and fits 12s4p with nese modules that takes more space. Maybe 12s4p is not possible but 11s4p is also worth it.
Hey there, very new here (to the point that I am still unable to start my own thread asking my questions haha), but then I saw this noob thread which is obviously perfect for me!
Iāve been searching and reading, but Iām hitting a few walls for a couple reasons - Iām in the UK (so 90% of whatās here wonāt help me as the parts are US only), and Iām not really looking to build what the ānormalā e-board build seems to be. So I figured iād just put up what Iām looking to do, and see if the end suggestion is either a specific DIY build config, or just buying a cheap pre-made!
What I want is a stable platform (so probably longboard), but which would need to be able to handle the rough UK roads (so probably pnuemo tires). Top speed is NOT a goal, as Iām unlikely to ever need it. Much prefer longer range and stability and control over top speed. HOWEVER I would be taking it onto grass and maybe even onto beaches, so I guess torque is needed?
Questions end up being -
- Longboard with tyres possible, or would I need to go for a mountain board? Is there issues with this?
- Would a dual-motor setup be needed for grass/beach usage?
- What kind of thing would you suggest for my needs? Would modifying a cheap pre-made be better, as top speed isnāt a requirement?
Hopefully you lovely people can give me some pointers on my somewhat weird setup. Iām going to carry on looking for recent UK based builds and see what others have done
When it comes to adjusting throttle curve for brakes is it the negative number (ex.: -12) that creates less aggressive braking or is it the positive number? Also, is it really necessary to adjust pos/neg ramping time and throttle curve in FOC?
Does anyone know where I can get this?
Digikey or Mouser. Looks like 220Ī¼F (microfarad) and the voltage depends on where you found itā¦
Motor Max: max torque at low speed
Motor Min: max brake at low speed
Battery Max: max torque at high speed
Battery Min: max brake at high speed
Both āMinā should be negative
Thanks. This came from the feather receiver. I was switching my electronics out and this got caught on one of my wires.
Iām just waiting on @StefanMe to pm me the specs. He said I could still use the receiver without the cap but Iāve already switched remotes.
Are these welds good?
Thoughts on this? Just got a non-programmable dual ESC from DickyHo and I think itās pulling to many amps, the battery can do maybe 30A but the ESC can draw 70A and I donāt want to kill the battery
