This is definitely a display setting, not an update.
When you said you tried to edit the appearance, thatās the part appearance right? Like how you also would edit color, texture, etc?
The visualization setting should be elsewhere, and superscedes any appearance settings. It allows you to view normally, as a wireframe, wireframe with ghosted background lines, and wireframe with no background lines.
Well I did not change anything myself, it came along notification about the update being applied.
Tried now to reset to default settings and same issue.
Why the f** would they fu** with someones settingsā¦
Ok I got it, thatās the kyeword I was looking for, googled how to set to wireframe and at the same time found where options for that are.
They donāt; never do this. This will fuck up the threads and strip it out and make it weak. Plus you donāt want these failing while youāre riding.
I did but I almost always have to ātapā the imperial nuts first before I screw it in all the way. This is regardless whether Iāve used them before or not. I donāt think it has the correct pitch for the m5s. Iāve stripped a few nuts from this. Iām probably doing something wrong.
The 10-32 nut fits with a very tight tolerance on the M5 bolt. The other way around is loose and should not be used as you said.
The pitch is almost identical 0.8mm vs 32tpi/25.4=0.7935mm
The best way is to first use an M5 tap on the 10-32 nuts to avoid seizing.
Why are you saying that? As I showed the pitch is the same and if you check the same goes for the minor and major diameters. The small differences are taken care off with the use of a tap. It is not magic.
Do you have a source for M5 nylock nuts that are 10mm across flats? If you do I would love to know about it since I have been unable to find any.
I donāt; but regardless of whether I did or didnāt I still wouldnāt thread FUB hardware onto metric hardware. I would just get M5 nuts even if it wasnāt 10mm across flats.
The problem with m5 nuts is that you need a washer under them since most truck baseplate holes are oversized plus they donāt fit a standard skate tool.
