@Benwebber reply here
Is it a bad idea to short a car battery with a solonoid and a momentary switch to be used as a spot welder?
Legend has it the answer is yes, a car battery will put out like 1000 amps if its warm so youāll need a beefy solenoid and a pulse of like 1 ms
Put some metal rods in the box near the outside of the package so the board canāt get bentā¦or make a wood frame to put it in
Itāll cost more because weight but they canāt crack it in half or crush the parts
Shameless self promotion of a Chinese Company by an account made 25 minutes ago?
seems legit.
This is not the place to advertise. We let this go and it will be bedlam. Not appropriate.
Rant over.
Just gonna go ahead and subscribe their email address everywhere I can
Charging port. Which one is positive terminal and which one is negative?
Plug the charger in and use a volt meter to check it.
Good call, thank you.
I have 2x 6s 12000mAh batterys [Lipo]. Constant discharge 12c and max discharge 24c.
I connected them in series and rode 20km.
If i plug one of the batteries into my charger it says ~26%. But if i connect my new batterymeter it says 53%. Shouldnāt all be either 26% or 53%? [The Image of the charger charged for a bit so its not 26% anymore]
Where both batteries new when you first created the board?
Yes. I bought them from hobbyking.
I know now
I filled my teachers email after he gave me a grade I didnāt deserveā¦ Always funny to see his blownup inbox on the projector
I mean what Iām a good kid.
Iām new here, so hi to all !
My problematic setup: I have 3x3(9S) LiPo Batteries (Zippy 40C 6,2A) and a 10s bms bypassed for charge only. My BMS starts with B- and then B1 up to B10. This is my BMS: www.amazon.de/dp/B07CMB83RN/ref=psdc_1626845031_t4_B07G2CSMHD I didnāt connect B10 as I have 9 cells. My Batteries have 4 Balancing wires for negative,Cell 1 to 2, Cell 2 to 3 and positive. VESC 4.12 and 230kv 3KW 6374 motor by the way
Now my question: Which of the balancing wires shouldnāt I connect to the BMS ? is it the positive or the negative wire from the Batteries. Where do I start ? This confuses me as there are posts which say different things. ?
Second question: Am I able to use Regenerative Braking with the bypassed BMS without destroying my Batteries, because I could potentially overcharge single cells while breaking downhill ?
Thanks in advance !
Fusion 360 got updated and now objects after extrusion look like that: When I even try to change appearance nothing happens. Whatās going on? I canāt work on something like thatā¦
You should not use a 10s bms for a 9s pack it is made for a 10s battery so you need a 10s battery.
