Im not a banna im a apple
it was not about you. @moon posted once a picture of the fishpaper after he received it. as scale to understand how much it is, he laid down a banana on it.
he has so much fishpaper, if he one day would be homeless (what iĀ“m sure he never will) he could just sleep in all the fishpaperā¦
Oh lucky him , one day Iāll have that fate too
is vibration damping important
Iām really not trying to sound like a jerk bit youāre just confusing me so much. Like, you say youāre great at woodworking so I have to presume youāre a decently smart dude, but youāre asking barrages of somewhat strange questions and it looks like youāre putting no effort into the quality of your work(hot glue stringing everywhere, poorly applied electrical tape)
But to answer your question , vibration dampening is extremely important in esk8
Ok well hot glue stinging can be removed , and itās like the 4th time I took apart this pack , so it will never be as near as fist time , for the vesc and stuff I might just use memory foam to ramen vibration then the basrtyys craft foam
Things I tried to get my issue to work: FOC sensored - (preferred defaulted setting) same results FOC sensorless - same result FOC hybrid - same result BLDC - magic smoke (bad motor only)
Sadly, I didnāt get the to switch the wires like you suggested. I already ordered new motors last night.
So check this out, unity still works (powers on, able to connect via bluetooth). I decided to hook it up to my PC to see if I could somehow check the logs. It wouldnāt connect. Hmmm maybe the cable wasnāt āseatedā right, which happened the first time I did this. I go unplug the cable. The flipping port came out with it . I was like WTF. It seemed like the port is not soldered to the board. It was held on to the board by 4 small hooks.
So boys and girls, be careful when you unplug the cable from the type C port. Those thing arenāt soldered to the board. At least mine didnāt.
Is the Pelican 1040 a good option as a focbox casing? And how would i mount it on my trucks? What 12S BMS do you suggest? What Charger do you suggest? Can i split the output to load 2 batteries at the same time? Whatās a good spray to protect my electronics from water?
Pelican case idk somebody else need to answer this. Why you want to mount it on the trucks? Bms- charge only? Split the output- so you want to charge lipos or LiIon? If you know what you doing than you can parallel charge them, but it will also take double that long
So i can have max battery charge only bms, iād say liion, just want to know if iāll able to load 2 packs at once with 1 charger
You give very less info on what you want to build. There multiple answers to your questions possible but for this you need to tell a bit more. The case you can just bolt on or drill some threads in your deckā¦ again we donāt even know which deck you have. I also still donāt get why you want to charge two LiIon packs at one time if you but everything in your enclosure you have only one battery there. Charge only bms I would say d140 from bestech rocks always.
Iām going to have a top and a bottom mounted battery, probably separating the front and back side (escs) Itās a Landyachtz Evo 39", i want to mount my focbox cases over the trucks, so iād need some adapter (if that exists) or build something. but without having the items iām a little bit unsure.
TLDR; Iām building an EVO in the style if an eMountainboard
Iāve had 2 USB jacks come off like that. Not on Unity, but on other VESCs. It fucking sucks. Hopefully the new 2019 firmware and tools will make USB redundant. The new software wonāt work on Unity though unless enertion works on it.
I know man. Talk about bad luck. Geez.
Iāve already gotten online w enertion help desk. Theyāre gonna replace my unity. Downside is I need to wait for the replacement. They said āhopefullyā by March. Ouch. Iām sending this defective unit back to them right now.
Shit. This means I have to use my spare 2 focbox. Iāve already got a good layout for all my electronics in my deck. In addition to it, Iād have to drill a hole for my loopkey.
Loopkeys are super-reliable anyway. It wonāt disappoint you.
IMHO they are still the best option at this exact moment
'course that could change any dayā¦ but so far they are reigning King
Building the switch and ESC and other ESC all into the same unit is a terrible idea.
If these were FOCBOXes, youād still have one good one that wasnāt broken, but now the whole Unity is toast
Likes donāt count in PMs either.
Hi. I was wondering how do I change and buy the rear/hub wheels if they get damaged or just wear out on Raptor 2.1? Or is the only one selling them Enertion? Would be weird if I have to order complete set of wheels with hub if I need replacing!
The best solution is to locate the motor on the outside of the wheel instead of on the inside of the wheel
If itās not the antisparj xt90 is that bad for the vesc
