Ok Iāll do that then. Itās just that 10$ + 10$ + 10$ I think Iām around 150$ of additional stuff.
I think Iāll go with soldering the wires directly together because I already see myself struggling more trying to solder the flat wires to those connectors than directly to the VESC wires.
Also it looks like I saw this was done already:
and it seemed to work soā¦
hey guys thanks so much for hgepling me out , ive been rideing my board in https://www.betteshanger-park.co.uk/ which is great long truch , board so fast but sadly my brother came on it and now it just cuts out not sure why any idias , i ty recnfigyreing the vesc but nothing, im colour blind but my freaind saw a red light when it cuts out
I would not have two chargers in your house at different voltages (42V, 50.4V) with the same plug on the end. Use a 5.5mm x 2.1mm barrel plug for the 2A one
You can use XT90S anywhere you can use XT90, and the male plug are identical. The female XT90S has a resistor and a ring inside while the female XT90 does not
Help,
Bought using a maytech mtdu30a dual esc with their remote. How can I pair/bind my old wowgo/meepo/hobby wing remote to it as the maytech has failed.
When soldering on new wires on old motor wires how much heat is too much? I just tried soldering on a sacrificial motor and those puppies get HOT! Hot enough to melt the enamel? Not sureā¦ But considering I want to shorten the original āsturdyā cables and add longer extensions, I donāt want to melt enamel at the statorā¦
The china stuff you canāt pair new remotes to them. Only if they have a separate receiver and itās not built-in to the ESC. I would contact the seller
Iām doing want to use that remote again as it jammed when braking. How about this. (attached pics) would that reciever work. Or do you know a SAFER remote that is compatible.
