Do you have any links for this claim
Not that I donāt believe you but its always nice to have it proven
Donāt remember exact locations, you would have to google it yourself. Also itās not like Tesla doesnāt charge to 4.20V for no reasonā¦
Itās one layer of protection, the charger also should not go that high. Also I want my battery to be able to be overcharged if it means my brakes keep working. Iād prefer a shorter battery life then streetface in certain circumstances.
Basically it is keeping you clear of āstarting a fireā area but not ensuring you use it properly. Itās just a failsafe.
Is it okay if we duckgo it instead?
The problem and whole reason we have BMS is that you canāt rely on the fact that charger stops at X voltage which should end as 4.2V/cell because you can get all cells at 4.0V and one at 5V in fires and have same correct X voltage
You make the claim, burden of proof is on you. Donāt try and fuck around and argue points that you may or may not have any idea about.
4.35v thatās over volt protection, like from a regen system attempting to pump more voltage than itās designed for.
given the right charger itāll never over-volt, right, 12s charger max voltage is 50.4vā¦so it canāt go above that. nowā¦if someoneās being funny and used a 60v cc/cv charger on a 12s or something, yea this bms will stop it at 4.35v, but donāt do that.
anyway, in esk8 application does not apply since both upper and lower voltage cutoff is configurable via vesc.
and yes, charging to less than 4.2v yields longer cell life. iāve asked bestech if they can balance charge to 4.1v and was straight up denied.
Itās from one of the 18650 cell datasheets, canāt find which one tho.
Thank you for that. Lots of useful stuff there. I think one thing to think about with this topic is that just because a BMS can go up to 4.35V doesnāt mean that it always will. Doing this a couple times over ~300 cycles will not significantly degrade performance. BMS protections are the exception, not the norm.
So have dozens of other people on the forum. This doesnāt make you a special snowflake. Please just move on
Its getting interresting
Hi, Iām gonna build my own longboard deck to replace the deck for my first build. Iāve never made one before and Iāve done my research. Does anyone know where to get the right wood, preferably 1/8 Baltic Birch?
@Arek honestly there is no reason to argue with @b264 he is a debate Jedi. Some of his stuff I donāt agree with but he definitely does know what he is talking about with this.
(post withdrawn by author, will be automatically deleted in 24 hours unless flagged)
Ok sorry, I wonāt do that anymore. Iāll just flag you guys. If this is how you do itā¦
has anyone ever used this esc. just wondering if it would be more reliable then some vescās
Thank you wondering if 8s would be a bit to slow. although i can always change the gearing
