Is it normal for the TB vesc to beep when you are breaking?
which are the best hubs for 6x2 wheels of aliexpress?
Mbs knooby or chap 6x2 alibaba
Hey, I’m running dual focbox with dual 6374 and a vtc6 10s4p battery (potential of 120amps continuous) with an 80amp continuous bms. I’ve heard that the bms cuts power at 120 amps.
What should I set the Absolute Max value in vesc settings if i will be running around 55amps battery max per focbox?
What BMS do you have. The bms is related to the battery. You could probably do 70amps and be fine
why not use ball bearings in the 8x28x9 superstars to put them on a longboard
Well on a regular cast truck the weight of the wheel would probably snap the axel
what a longboard truck would be ideal for that?
superstars your going to want trampa or msb trucks
I was thinking of machining my own trucks with a friend
you would need high grade aluminum like T6
What wheels are better mbs rockstar or trampa superstar
Both great.
Yeah if you want you can change it to 120 there are some really good videos on YouTube about configuring a vesc.
okay thanks, ill check them out
6061 t6 10 char
Yep that would be what you want
Does anyone know would the 9.5 mm bearing from MBS(linked below) would work on the Trampa mini spring trucks?
Tramps website says 9.525mm, bearing says 9.5mm, does that 0.025mm makes a difference or they are the same diameter?
