hahah oh is the sk8 the same as the sk3
wow bro thanks ye thats y i got the racesytar thought it was good
and thanks to u bro
rthanks bro so thats a sensord motor
yes sk8. sk3 no
thanks so much bro ye i will go with sk3
I still would do sensored as if you are in binding you will have to push start and then get your foot into the binding.
Go with the sk8 and just make some phase wire extensions cause the phase wires are super short on the sk8’s for some reason
ok i will see bro thnaks do u know how to program vescs
or as i should say oesc
Hey, how much of a difreance would it be going from dual TB 6374 motor setup to the same kv turnigy sk8? (one of mine Tbs have a broken winding, but it costs basicly more than 2 sk8s after import)
You would have to check the watt output.
I’ve got a set of both and there is no noticeable difference in performance between the same kv 192 -190 even though the sk8 shows a higher wattage on specs.
well the amps are the same, as for the watage, sk8 is 2800 and TB one is 3200. Edit, Maybe someone knows or could measure these distances…?
hello, I have the same motor, It’s very powerfull and cheap. The only worrys is the shaft (6mm) and the diameter for the screw to fix the motor is 25mm look the draw 2D from motor.
And I had some problems with my mount, https://www.ebay.com/itm/DIY-Single-Motor-Mount-Bracket-Parts-For-5065-5055-Motor-DIY-Electric-Skateboard-/371796600927 ( is not the best but the cheap XD)
Becouse, I just can use two screws, and this happen to me https://www.electric-skateboard.builders/t/belt-get-loose-when-i-was-driving-video/70436
Yes, you don’t have a key hole, but you can use a grinder to make a flat surface on shaft , at least 2 flat surface for you can use a gear with screw like this: https://www.amazon.com/Lannmart-Electric-Skateboard-Pulley-Accessories/dp/B07HSVRPBT (you have three holes for motor gear) and you can use a glue for the screw dont go out…
the accessory that came with the motor, when I saw I was (WTF?) how I use?, but I found how to use three days ago XD
When you tighten the nut, the connection with the shaft is very powerful, but you don’t feel safe with just this solution (off course) just saying how to use.
dont buy this mount… the gear and bets is good, but the mount no
Anyone has a trick to get rid of fracking chewing gum on grip tape?
ice and grip gum
I personally use a concoction of engine degreaser, a blow torch, isopropol 99% alcohol, and enzamatic biochem used for crime scene cleanup. Cleans up pretty much everything, just make sure not to leave it on too long or it starts eating away pretty much everything bar metal.
