What you need to know?
how to program my vesc on vesc tool
you can connect without getting the message FW too old?
no i have done that stage its more like what numbers do i put in to make sure my board gets the best it can handle
my motor makes a werid like nosie
there are different parameters we need to know to give you some recommendations. Did you already read through this:
What and how you set up your vesc at the moment?
videos always good to understand which noice it is
ye i undersatnd what the vesc does but for example i dont know what amp to put in for my battery or what watt my motor will run at like that stuff
it should be written everything in thread i linked you.
Look, as min we need to know
- which battery you use
- singel or dual setup
- which motors and gearing
- where are the vescs mounted (airflow yes/no)
ye i am using a 10s3p lg cell and a 200kv racestar motor vesc gets a little air flow a single set up and i am using the oesc from miami boards
which LG cells you using?
and please which racestar, size of motor. or maybe you know till which max current they rated?
li-ion 36v 6.6ah/237.6wh
max charge 42v
i dont know the lg cell type
is it a pre build pack? you should know how much amps you can get out of your pack. for this you need to know the cell type used in the pack. if it´s just a 5A cell, you shouldn´t ask more than 15a from the pack
does a broken winding mean a new motor?
um is is a brh5064
Question…
Is the diyeboard v1.1 esc programmable? Can the Ackmaniac BLDC tool be used on this? I want to know if I can vary the throttle and braking response with the hand controller.
Project wowgo upgrade! |Stock wowgo | Paris v2 | Wowgo hub motors |6.4 Panasonic(I think)| Stock ESC
So I have been looking a lot into upgrading my wowgo2s. It is a great eskate but I want something with a bit more torque and hill climbing ability. I am going to be doing this all in little pieces. I was looking at getting a focbox unity right now and later switch to a belt drive system. Any thoughts? Would the focbox unity work with my stock set up and remote?
it will probably work with the hub motors, it will still be lackluster though, but ti likely will NOT work with the remote.
@mmaner It will still lack luster? Do you think it will be worse or just about the same? Because I dont expect to have better performance until I go to a dual belt drive system.
p.s I follow you on insta! You need to tell me more about your gear drive set up, like how do I do that?!
