Here’s how to build a nice enclosure using Ikea table. Video by prusa.
Are these decks still available? Especially the wood deck
yea I have a bunch of the two hole above. 120$ each.
I picked up a single hole from @uigiroux… fantastic deck, looking forward to finally starting my build
Glad to hear you got it! Was there any damage from shipping? I wrapped it pretty tight I thought, just want to make sure
Finally decided to hand route this deck with a dremel. One side went smoothly. Then I make the others side too wide (2mm) because the metal track I had c-clamped on moved without me noticing.
Oh no… Worried about flex now?
How much wider were you going to route it?
I don’t think I took off enough to do that? I might ask @sender if he can add a layer of CF in there for me.
Damn what are you putting in there?
That’s what she said
Its a pretty thick deck. You’ll probably be fine. Might try mounting trucks on there and give it a light bounce
Actually not sure. But orientation of cells would be length wise so needed a bit more width. I need more since this deck will likely be with pneumatics
What size battery?
Just 18650s. Pack would be built in this form (this is a 10s3p). So 4p would be 8 cells across and 5p would be 10 cells.
How much did you route? I’m hopping that my battery fits, but will take of at least 15mm length wise
Anytime, just LMK!
Looks like it might be fine as far as having space for inserts. Probably need to epoxy them in just in case. As you can see the right side is all smooth, the left side looks like I chewed it I didn’t want to smooth it down because it would take more off
Did you run the Dremel the same way in both sides? If you run it contrary to the rotation you getters better control, push it against the direction the tool wanna go
