Sign me upā¦ tried the link, and itās read only
Me too, read only.
@hyperIon1 Ask the if the sensor assembly is brine-proof (not brine-resistant)
Of course we know the bearings wonāt be, but ask about the low-voltage bits please
Ask if they use conformal coating on the sensor parts after theyāve been assembled and soldered?
just a sec
try now, it should work now
I tried it and it seemed to work.
Works now, perfecto
Damn bro!! What are you planning on doing with these beasts??!! I want some now
2 for me pls
Well these would be using my 8mm E-Toxx Helical motor pulleys, so 10mm is a no go.
@hyperIon1 If they do 8mm shafts, can you see if we can get them without that step down from 10mm-8mm where the shaft exits the can? My issue now is that my TB and old @JLabs 6374 have that 10mm step on the shaft and I canāt slide the pulley on far enough to get proper gear alignment.
I will ask tonight and let everyone know. I have some of the 6374 with the 10mm shaft and I like themā¦
we should get them logo-ed BAESK8
Iām confused. I donāt know what Iād put them on, but theyāre so big and cheap! And I have those metroboard pulleys I bought by mistakeā¦
In for a pair.
Iām in for a pairā¦ just filled out the form
Be interesting to see what these look like inside, how big the stator is etc.
I think the front bearing is also why SK3 are so durable, they have a big bearing in front that sits between the fan and the can. Most motors the can is just hanging off the rear of the shaft. So there is more potential for flex / vibration.
