I always thought it’s just important to change + and ground, which would be the outer wires. The order of the temp plus the hall sensors could stay the same but if I now think more about it…probably the temp also need to switch…
I had to when wiring my Flipsky 6374’s on my ESCapes. Tried motor detection before and after it only worked once the temp pin was also switched. The Maytech’s might be different but I doubt it.
Your thread gave me the info I needed to get that done so if you haven’t yet read through the thread he posted above @Silverline give it a go. It’s not too long
It makes sense. I mean the temp sensor should be something like a pt100 and the sensors, nu hall sensor. I don’t know the electronic background about it but they should work different, so they also need to be changed in the port.
For future reference
Red : +5v Blue : Temp. Green : Hall White : Hall Brown : Hall Black : Gnd
So what do you guys think? wait for the sk8 6374 till october? or jus buy the TB 6374? From what I read it seems just as reliable as the sk3s were and it’s $30 cheaper with added benefits with ofc added size and a sealed enclosure so nothing gets in
I’ve just bought it from the international warehouse. Shipping is free (DHL express) and the motors came today, just 3 working days, after i ordered (I’m from EU)
How do I find the international warehouse? The Global tab says it’s on backorder
Sorry i meant global (they send from China) I bought the 149kv version, wich is in stock.
yeah it’s on back order lol I need the 192kV my 10s wouldn’t work with 149kV
Anybody knows where to buy this collar or spacer, that comes with the sk8 motor ?? Its inside diameter is obviously 8mm and outside 9mm ???
Any ever tried to paint or change the color in another way on these motors?
well, they’re back in stock yall
I have a sk8 6354 motor from hobbyking and they run fine, but there is one problem. I drive diagonal and the can on one of the motor rattles. I can pull the can of the motor back just a bit, but that´s making a irritating noise, when I´m riding. Does anyone have any idea how I can fix that??
I’d try tightening the three screws on the motor around the shaft. Fixes issues for most ppl
Did you remember to use the collar that comes with the motor ?
anyone running dual sk8 6474s on dickyho mounts with tb218s 15mm belts?
Yeah, but it still rattles
Tried that. Didn’t work
Do you have a video of the sound/rattle ?
