Barely put my mountain board together and already thinking about upgrades
Is it safe to run 12S on these, without adding additional caps? *BLDC *149KV
I already know I won’t hit the ERPM limit with my setup.
Unfortunately, I have no engine what goes to 12S But I’m sure you’re using the system can also drive with 12S It would be very interesting to know how well it works with 12S
But i came by 12S SK3 6374 149KV motor by 12S/50,4V over 60.000 ERPM. (67.586) Ore i have a calculation error ?
ok, a little over the ERPM limit…but I currently never push full throttle. 30 km/h is scary enough offroad here. Just looking for more power to go up hill.
Using 2x5000mah 6S 60C, I can set each VESC to 50A (maybe 40 to stay on the safe side, currently it is set to 25).
How much amps can I pull MAX using a single ESK8 anti-spark switch for both VESC? I already removed the fuse and bridged the two pads with 12AWG wire.
