@telnoi
Sorry for this and this was for me very unpleasantness!
You can send me back and i refund your the shipping cost.
Tell me please in PM you order Number that i know
the adresses where i must sending the new controller.
I have not enough controlling my solder work.
I al time controlling al soldering work.
but there is that I do a probably a fault.
Attila very quickly provided me with the info needed to fix the issue. I opened up the case and soldered the wire in place. Please note that if you do this without esk8.deâs approval, you will void your warranty.
P.S. The PCB looks great. Very tidy, components all straight. The other wires were soldered correctly. There is no doubt in my mind that this is a high quality VESC.
Having issues setting two up via CANBUS.
When enabling can FWD in the upper right corner using the correct ID for the slave (2), I get ââno firmware responseââ
and only one motor responds to the Tx.
ON THE SLAVE:
Read configuration
Set Controller ID to 1
In the app configuration disable âMultiple ESCâs over CANâ!!! (enabled on master only)
âSend status over CANâ is already enabled.
Write configuration and reboot.
ON THE MASTER:
Read configuration
Set Controller ID to 0
âMultiple ESCâs over CANâ is already enabled.
@esk8 Did you split + and - wires at one edge of the board each ?
Regarding a old video of Vedder, as far as I understand this is not a good idea in matter of capacitance
I donât know what is the real impact on the electronics, but could be more reliable to keep them close to each other, right ?
I donât know why the Video was only in 720P
I am looking in the settings by youtube but i donât find
it that i Kan make the P higher.
And i loaded the original vide by youtube down.
I must looking thats i loaded the Vide from the SD Card.
I hope than was it better.
If I understand you correct, you are asking if he has the plus cable on the TOP side of the PCB and the minus cable on the BOTTOM?
Yes he is doing that, you can see that on the first and second pic in this thread.
I dont know if there is copper on the PCB where the cables are going. but if so, it is probably a groundplane which is the same as the minus cable.
nether the less the 2 cables are running parallel (only separated by the PCB (probably 1,6mm thick)) to the solderpads.
Therefore it isnât a problem in my mind.
and what you are asking for is the inductivity, not the capacity, as Ben mentioned in his video
No, I meant that he put a red wire (assuming + one) on one edge (toes side) of his Mountainboard from electronics to battery box and black one on heels side.
Youâre right, itâs inductivity.
I was on vacation and I have it also on the HP communicated.
Unfortunately, I had an accident on holiday with my board.
Unfortunately, I was also in the hospital.
Therefore the replies to the emails have been delayed a bit.
This is not a new product and no further development.
This is just a video of what a customer sent me.
But the question itself, yes, I have sent you the new Wheel Pulley Monday!
Yes thank you @ GrecoMan so slowly it will again,
I could hardly believe the first two weeks
do not can use my hands.
But we test all our products ourselves
