Are those 9 mm belts?
they are already out to the max, i did use spacers, 1.5 spacers on both rear wheels, any more out wont be able to put the wheel nut on.
290, 5M 12mm belts.
for dual 6374, you could use my 8 inch truck.
is it possible to get the caliber version in blank color? Or black or something else then blue?
I could spray it black for you.
… no thanks
Damn it’s been a journey to tune this pulley to perfection. @dickyho you’ve done a great job on this! I’m planning to get 2 of these to use with Caliber II truck. Does anyone know if they’ll go nicely with this wheel pulley from DIYeboard?
i dont see a problem. i have 17mm wide pulleys on mine.
What pulley are you using?
from @idea to lower weight,they are abs printed, because with 10s4p battery dual mounts ect, i am already at 11kg
Amazing work from Dicky, now just gotta widen those pulley holes a little bit.
Damn those wheel pulleys look so nice! $100 from any other source, if only they fit bearings in the pulley…
@dickyho do you think you could make your wheel pulleys kegel core comparable? It would just need to be 5 bolts around the axle instead of 6.
This
YES, THIS . Good stuff!
@dickyho Nice work as always! Question, if we add both mount + idler + pulley in cart, does it count as a single package to ship?
How much delivery time did it take? 15-20 days?
Yes. If you are worried about your order getting grouped together, you can also message him and order from him directly. ( if you do this he will also give you shipping estimations)
