i like the lines on the board man very nice and clean looking!!
I used Fvt120a ESC on my electric board. The reason for using the Fvt120a ESC is that it is cheap and does not emit high frequency noise from the motor when it is stopped like a VESC. It is loud with cooling fan sound and is not as flat as VESC.
Simplify wiring and integrate redundant circuits.
Capacitors were added. The upper JST has 12 voltage when 3 channel signal. The lower JST is for the voltmeter of the main battery. 6 cell voltage is coming out.
You must be mistaken, vescs donβt make a noise while braking
The power button will be fitted with a hole on the deck.
The ESC case is being produced as a 3D printer. I made an ESC cooling pen that responds to accelerations.
The bolt meta of the front truck should also be mounted.
