They should be 9 pin 6x sensor and 3x phase wires, each phase wires are payed to 30a maybe a little more and basically they do not need more then with current to drive the motors because if there higer gearing.
There motor stators are also a lot shorter then ones used in most others builds.
It’s the same connector that the ego cruiser uses
Hi, I just bought one and I’m a bit annoyed with the range that i get from it. So I was wondering, if I could use an external battery pack to charge it. I’m aware that external battery packs with an ac plug could work with the right size, but they’d loose a lot of energy converting to dc. So, how about if I find lets say a USB to boosted board plug, meaning dc to dc, I wouldn’t loose the energy for the conversion, right? Meaning a 100 watts external battery should be able to recharge my board quite decently…? Would that work?
Thanks
