14/36 is the gearing ratio, you have 1 pulley at the motor shaft (14 or 16 teeth) and a pulley at the wheel (36 teeth).
A bms is a Battery Managment System, it monitors your battery cells, balance charges and protects from over-charge, over-discharge and over-current. Also, its a pretty cool solution for single plug charging, keeps things clean and tidy
Depends on what top speed you want, 14t is 26mph, 16t is 30mph. Torquboatds sells them too, but depending on your wheels you might need a custom 36t one.
As for sparks, it’s an XT90S or an anti spark switch, depending on how much you wanna spend.
I think you were asking about the BMS tough lol, get 6s 60a from supower
for a power switch what do you suggest i found a cheap one for like $2 but does it matter what kind it is? and for a charger how do i get the laptop style charger and if i can’t what kind of charger should i get? what other things do i need for my board so far i got a motor an vesc belts/pulleys and such, battery, BMS, and Anti sparks
If you want to go cheap, use the Anti-Spark XT90S as a loop key, just search the forum for “XT90S loop key”. As for the charger, if you’re gonna use a BMS then you use a laptop style charger, you can get them from supower.
