Hey guys, I’m trying to mount my 12mm torque boards pulley kit, but I’m not entirely sure how…
The pulley sticks out past my motors shaft, does that mean I’m screwed? Also, it didn’t come with that rectangular key to insert in the pulley, and do I take the little circle clip thing off the bottom of the motor first?
So your motor shaft doesn’t go all the way through the pulley? That shouldn’t be a problem, as long as it goes far enough in. Which motor do you have?
The rectangular key isn’t really required, it does make it a little better IMHO, but you’d need a slot or at least a flatspot on your motor shaft to take advantage of it.
