I don’t trust my measurements with a caliper that they are correct so I need help from you that designed their own pulleys or lock nuts, they should be the same
Im not familiar with 3d design software that uses stl files or how do you guys even menage to work with stl files and share and edit drawings of stuff. But I know the basics of catia and autocad though…
Still learning those
So I basically need this dimension so i can machine my own sprockets
(distance from center of the axle to the center of the screw for pulley)
Im planning to use this on the other side of my sprocket to hold it in place
https://www.thingiverse.com/thing:1741501 (locknut)
I’m not sure if they have the same core, but my 100mm MBS All-Terrains measure out to be approximately 17mm. You might want to double check if Flywheels and All-Terrains have the same core because I’m not sure. Hope this helps!
