ive been building my board for a while now and riding it too. but earlier this week i had come accros a problem where everything on my board just shut down, including the battery indication that was connected straight to the on off series connector that i made. now only one of my vescs work but still, that cuts on and off with the motor and the other vesc is not working at all. i will be uploading pictures soon but in the mean time please help me figure out whats wrong. i had a 10s4p battery and dual vescs but it will have to now be a single motor build. please help and ask questions so i can get back riding
Try to remove everything between battery and VESC. Plug each VESC separately to the battery to test if they work. It may be a BMS issue or a switch issue or the VESC.
Iâve tried that, the battery is charging and Iâm reading 40V from the battery itself but one vesc that I thought was broken supplyâs power to the receiver but none of the leds turn on, on the vesc
So without bms only one vesc works, correct?
And with the whole setup (battery,switch,indicator) the other vesc works correctly?
If that is the case it seems like one of the vescs is broken. I am not sure if that is the main cause of the Robles since you mentioned that the indicator turned off too.
If he doesnât get faults and only the blue and green LEDs turn on then the MCU (stmf4) is fried or d4/5 are messed up. If the red led still works you should be able to connect to PC and use the terminal.
