Send me your address i have set just pay me the shipping
I think the seller should have them in a bag that comes in the with the bms if u have no luck let me know
Contact the person you bought it from first. He should have included the connectors
Those look like “JST-XH” connectors
The 8-pin version is sometimes referred to as “7S”. 2-pin might be called “1S”
I thought the same, that these were JST-XH, the same as used on lipo batteries. But its not.... they don
t fit.
Oh, my BMS from another vendor is different. Then in that case it is probably JST-PH
What’s the pitch between pins?
2.5mm JST-XH 2mm JST-PH (most likely this one) 1.5mm JST-ZH 1mm JST-SH
2.5mm same as JST-XH But the plastic connector does not have the same form facter like my regular jst-xh connectors on my lipo batteries
So, here is what I would do.
Basically, pull the plastic off the pins and connect JST-XH.
Or, alternatively:
tear the plastic until JST-XH fits
You mean hack it chop it bend it till they fit
Should have asked u to sell this one
Why bend it if the pitch is the same.
Just get the right block that fits i have them
Looked it up, in that case they should be:
2.5mm JST-EH
Not really common. But something you can search for.
Anyone have a spare 8 position JST-EH? They seem to be out of stock everywhere, and amazon/ebay prices are absurd.
Just solder the wires directly on
I dont but if i was stuck i would cut plastic cover off and solder the wires on
