I did some test yesterday and it seems to ride perfectly, but i have no breaks for too much time before the BMS unlock the charge (and i’m living uphill )
So i ordered a Maytech Rheostatic Brake, i should received it in 10 days.
Nice work but forgive me for saying this. The rheostatic brake is a bit of a band aid fix. That esc is set up with 10s voltages pre programmed in. You with the 12s battery will come across more issues than braking and those issues could potentially throw you into the ground. Seriously consider getting a 12s rated vesc based dual or 2 singles that you can set up yourself.
Anyway good luck.
I read that this particular ESC can handle 12s.
And during my first tests, it realy seems that the BMS was the issue : After the battery voltage loosed ~1V it started to break again.
This project is a street commuting board, particulary on cloudy days: no speed.
Thanks for the advice about VESC, i will check for an upgrade but i’m not sure about putting $200 more on this particular board.
